Had my ABS codes read now I need HELP!!!!!
I had my ABS light on for a while so i went in to get the codes read now i need to what to do next!!
Heres what the print out says:
tech confirmed concern and found that DLC fuse was blown & he had to replace to perform test///checkedfor codes & found C 1095 pump motor circuit failure// C 1096 pump motor open circuit.
thats exactly what it says.
does anyone know what this means or what i can do about it?
Thanks alot,
Derek
Thanks alot,
Derek
It sounds like you should test the pump. It plugs into the bottom of the abs module. Just follow the brake lines from the master. I have a '97 and you pretty much have to remove the module to get at the pump, but yours might be easier to get at. Even if you have to remove the module it's easy, a few screws and it comes off. It doesn't need to be bleed if you take it off. After you get to the pump, see if the wire connector from the pump to the module is tight and clean. If so, you can jump it to the battery to see if it will run. I did this to test mine when I had to replace the module.
