22 or 24
Old 07-29-2006 | 02:36 PM
dmitt30's Avatar
Originally Posted by affordem
these pics may help you produce some ideas on what your truck may look like with 24s. View link
https://www.f150online.com/galleries....cfm?gnum=8061
Dude... That is hands down the hottest f150 I've seen on here. Absolutely gorgeous. What rim is that, how much did you pay for it, and where did you get em?
Nice ride.
Don
Old 07-30-2006 | 04:52 PM
DoinBigThangs's Avatar
So will a 305/45/22 tire fit on a 2005 supercab 2wd without any rubbing? I would rather run a 45 series than a 40...let me know, pics would be cool
Old 07-31-2006 | 12:47 AM
madjay97's Avatar
BIGthangs- if you find out through another means other than this site please post it. I have been holdin off my BIG purchase for a week because of this same issue. the 45 series is definately my preference too. I believe wandell runs 45's but i am not sure if he had to do any modifying.
thanx
Old 07-31-2006 | 01:50 AM
Ive seen them on 2wd and they looked to fit fine, a little tight up front but didnt appear to be a problem. Possibly they did the 2" front level but I think they looked stock. I'm pretty sure they would fit
Old 08-02-2006 | 09:01 PM
so does anyone know for sure or?
Old 08-05-2006 | 12:13 AM
madjay97's Avatar
i just found out just now that this same question is answered under a different thread. under powertrain, then wheels & tires, then 305 45 22. i wish someone told me earlier i probably would be sitttin on 22's by now anyway my 22's are ordered should be here on the 11th i'll definately post pix.
out
Old 08-05-2006 | 03:02 AM
crand002's Avatar
24's are the way to go IMO. And no you don't need bigger brakes. My truck stops just fine.
Old 08-05-2006 | 06:54 PM
madjay97's Avatar
24's?
you must have nice roads where you live if i rolled 24's here in Md my rims wouldn't last a summer. what size rubbers u got on them?
Old 08-07-2006 | 02:30 AM
crand002's Avatar
The roads suck here in San Diego but I don't care it is a small price to pay. Everyone who rides in my trucks says it rides great. 305/35/24 but I wish those new 295/30/24's were out when iI got my rims.
Old 08-07-2006 | 02:32 AM
jmarvolous's Avatar
just make sure your ridin dirty
Old 08-07-2006 | 06:54 PM
Grandthroblord's Avatar
235/75/17= 30.87 Diameter (stock)
275/55/20= 31.9 Diameter
275/45/22= 31.74 Diameter (2006 Harley)
275/65/18= 32.07 Diameter
305/40/22= 31.60 Diameter
305/45/22= 32.45 Diameter
295/45/22= 32.45 Diameter
305/35/24= 32.40 Daimeter
295/30/24= 30.96 Diameter
As you can see 24's are almost the same size as stock!!!!
The worst tyre to go for here is 305/45/22 as it is over 5% larger
But
Who cares I want looks and comfort so thats what i have gone for they are being imported as I type this
mmmmmmmmm
I started a thread similar to this and was sent this tyre calculator (the best one I have ever seen even shows you tyres to buy in the size you specify!)
http://www.1010tires.com/TireSizeCalculator.asp
Would not like to hit a pot hole with those 24's the side wall is 88mm just over 3" look good thou
Dont understand why you would need upgraded brakes as the overall diameter is around the same
Tyre width would put more load on the suspension under braking and also more on cornering more grip means more body roll sooooo
when you upgrade wheels and tyres with low profile wide tyres you should also upgrade your suspension
But
No point being able to go forward without stopping and if you have upgraded the tyres and suspension which if done right should improve cornering then upgrading the brakes will allow you to push the limits of your new tyre/suspension upgrades
Offset is the one to worry about KPI King Pin Inclination too much rubber on the inside or outside will be detrimental to your steering
Theres my pennies worth feel free to shoot me down
Old 08-16-2006 | 03:58 PM
madjay97's Avatar
305/45/22
i just put my 22x9.5 Giovanna gellos with 305/45/22 rubbers. They are the way to go they fit absolutly perfectly with no rubbing just like wandell said they would. i'll post pix shortly.
Old 08-16-2006 | 04:04 PM
madjay97's Avatar
tires
oh yeah pirelli scorpion zeros are the way tog if you want a soft ride. i had a set of falken ziex s in the past and they were very hard compared to these
Old 09-12-2006 | 08:39 PM
jokergomez81's Avatar
I'm not ever going smaller than 24's, my truck gets to much kudos, I also have the stock brakes but did, put 70$ pads on. work great stops on a dime. next mod will be lowering kit just like (crand002) his setup is sweet. Nitto 420s 295/35-24
Old 09-13-2006 | 07:09 PM
cehowardf150's Avatar
Anybody towing BIG TRAILERS (7X14 ENCLOSED AND LARGER) with them pretty wheels? I have ordered a set of 22x9.5 with 305/40-22 tires, but I might be backing off, because 95% of the time I am towing a 7x14 enclosed trailer with 2 or 3 bikes aboard. And might be going for a 8x16 enclosed trailer in the near future. Don't get me wrong, the big wheels looks super good on the F150.. But, are they practical when towing or using the truck like a truck???
