Just curious-I know it has been discussed before, but I just put a set of 285/70/17 BFG AT's on my truck (thanks for the help Wandell) and Bell Tire put 34 lbs in them. What should they be set at? Thanks much
I don't think you will have a problem running 34 psi, but you may get better gas milage with a higher pressure. I'd bump it up and see if the quality of ride suffers. I'd shoot for something in the 40 to 45 psi range.
Thanks guys. I put 42 in them and the ride is pretty good. Although I have a shimmy at 65........don't know if I should take them back and have them check the balance.
