285/70-17 or 295/70-17
How much you crank them up is a topic of debate. Personally, I think you are alright to crank them up all the way with the OEM adjustment pieces. The point of concern is the CV joint angles. If you get too much preload on the torsion bars, it can put the CV joints at a severe enough angle to cause premature wear. Anyway, just crank each adjustment bolt and equal number of turns untill you get the ride height you want. Most people lift the front of the truck off the ground while doing this. Also, it's not unusual for the two adjustment bolts to be set at different amounts of preload from the factory. When you are through, you will need to have your front end realigned. Here's a pic of one of my torsion bars and adjustment cam. There is one on each side. The torsion bar is the long round bar. THe adjustment cam is covered in surface rust and the adjustment bolt can be seen on the bottom of the cam.
