Are 35's to big?
Are 35's to big?
Ok I need some feed back, and before you start flaming I have done plenty of searching.
I am currently running 33's with a 2.5" SkyJacker leveling kit with a 5.4 and 3.55 gears.
I would ultimately like to step up to 35's with a close to OEM size aftermarket wheel.
Now this is where I need some input. Would 35's with a leveling kit be to much? I know that they will fit, but will they be to much stress on my front end do to the angles caused by the leveling kit. My truck is an everyday driver so keep that in mind.
The reason that I am asking is because I plan on regearing.
I am going to get 4.10 if I stay with my 33's and get 4.56 if I step up to 35's.
Any info, especially from those of you that run 35's with a leveling kit would be appreciated.
Thanks,
Doug
Thanks,
Doug
