Tires
Tires
Sup fella's new to tha site but can already tell its a goodie!! im fixin to put me a 2.5 inch leveling kit on my 04 fx4 now i realize that there alot of guys posting diff stuff on here but i wanted to post one for myself i just wanna know how big a tire i can run is?? i kno they say u can clear 33's but whats that equal to in like a 325 60 18? see the thire im also looking at getting is the kumho road venturer AT inthat size im just worried about rubbing issues anthat sort im goin to run my stock wheel also so i was just worried about all the rubbing clearin issues with it. ive searched for a 305 60 or 65 18 but havent had any luck other than the bfg allterrain ko that comes out early september.. but i dunno i just thought that there may be some dudes out there that ran in the same problem... the type of level kit i got is from http://topguncustomz.com/ so if u have any info about it id apprechiate it!!
thanks an git r done!!!
Yes, a 325/60-18 is basically a 33x13.00-18 tire. They will fit fine with only a leveling kit. However, the OEM 18x7.5 inch wheels are a little narrow for a 325mm wide tire. This can cause the center portion of the tires tread to wear slightly faster than normal, similar to running too much air pressure. They will fit and look better on a set of aftermarket 18x9 inch wheels (with 5 or 5.5 inches of backspacing).
Also, welcome to the site.
4Wheel Parts and Discount Tires usually have some good prices. Both carry Nitto Terra Grapplers, which are probably your best value in tires. Discount Tire carries their line of MB Motoring wheels at reasonable prices, but they can get any wheel made. 4Wheel Parts usually has good prices on Pro Comp Xtreme Alloys and Mickey Thompson wheels.
