2002 F150 Rotor's
2002 F150 Rotor's
I have a 2002 F150 FX4. I ordered a set of front and rear rotors for my truck from NAPA and they said that my rotors will have 12mm stud holes. I was reading on here today that my truck actually has 14mm studs. Will the 12mm rotors be interchangeable with the 14mm rotors? I read a post taht stated the 12mm studs actually have a ring at the base of them that is 14mm? Is this correct or will they not fit? Has anyone else had this problem?
Thanks for all the help.
I have been looking at pads and rotors for my 2001. Every part store that I contacted had a listing for both 12mm and 14mm studs for the rotors. I ended up finding on the face of the rotor a stamp that stated 14 mm in between the stud holes. I woould suggest taking off one of your tires and check to see if there is a stamped number on the rotor. As previously mentioned, 12mm is smaller than 14mm and I do not know if there is a ring or not. Maybe someone else will chime in with other info.
Good luck
