these fit?
these fit?
Mickey Thompson Baja Claw Radial
LT325/60R18 (33x13.5R18LT)
M/T5780
on my truck with just the 2.5 lift and the rims i got? dont wanna change anything on my truck now......not worn in enuff ........but will this tire fit on the rim and in the well without rubbing?
or...
BFGoodrich Radial Mud-Terrain T/A
Size 35x12.50-18 LT
Solid White Letters
Load Range D
these are 35s? but if i get these tires would i need to regear and will they fit cuz i got a deal on them if i could and performance is not affected
M/T5780
or...
Size 35x12.50-18 LT
Solid White Letters
Load Range D
Well, they will fit but 7.5 inches is too narrow for a 325mm wide tire. Usually running a tire on a rim that's too narrow will cause the center portion of the tires tread to wear slightly faster than normal, similar to running too much air pressure. A few members here have installed 325/60-18's on their OEM wheels. Maybe they will post an update on how they are wearing.
