Muds or All terrains
Old 08-30-2006 | 09:57 PM
hsimpson180's Avatar
Ive got a 1999 f150 2wd lariat. I want to put bfgoodrich all terrains for my next set of tires. I dont know if you guys think that muds would be better or not? Also, what do you think between a 275/70/16 and a 265/75/16? Thanks.
Old 08-30-2006 | 10:12 PM
MmmBuckles's Avatar
well the muds will definately look alot better. but they wont last near as long on concrete. the a/t ko's are much better choice for everyday driving. and i would go with the 265's, you might have some rubbing problems with the 275's
Old 08-30-2006 | 10:21 PM
ok thanks. i have heard that the muds wear a lot faster. i think i will go with the 265's. Do you think i should put a locker in the rear of my truck even though it has a posi?
Old 08-30-2006 | 11:44 PM
Johngs's Avatar
Get the 265/75R16 BFGs, they are about as big as you want to go on a 2WD, Ive seen a few with that setup and it looks nice.
Why would you get a locker? (that means I would not get one...especially on a street truck).
Old 08-30-2006 | 11:52 PM
Adam06FX4's Avatar
Registered User
if you already have a limited slip there is no need for a locker unless you get into alot of situations where one rear tire loses all traction (one tire being in the air and spinning)
Old 08-31-2006 | 12:06 AM
Thanks for the help guys. I think ill go with the 265s and do without the locker. Can you lock up the front end of a truck if its only 2wd? I thought somebody told me once that you cant. If it is possible, is it worth it?
Old 08-31-2006 | 01:04 AM
Johngs's Avatar
No, you cant. The front wheels on your truck are not connected to the driveline, thats what makes the difference between a 4x4 and 4x2; therefore no ability to lock them (no necessity, because no power goes to the front wheels).
Old 08-31-2006 | 11:19 AM
ScrewedUPF150's Avatar
I have 265's on my truck and wish I went bigger. I am planning on upping to 285's next time. 275 is not a significant jump from the 265
Old 08-31-2006 | 09:09 PM
ok thanks. Now i understand why i cant lock up the front of my truck. I am still thinking about if i should put on the 275s but do you think i will have rubbing issues when i go over rocks?
