Will this rub?
Old 09-01-2006 | 01:29 AM
Mange's Avatar
Will this rub?
18x9 Moto Metal 951 with 6" Backspacing; 325/60-18 Nitto Terral Grapplers. Concerned about the width. This would be with a leveling kit.
Old 09-01-2006 | 01:37 AM
crashryan20's Avatar
yes if the rims are 9 inches wide, tires are 325's which i believe is 37" or 38" with only a leveling kit would rub, if you are ok with trimming then you could take a grinding wheel to you bumper and maybe even take out the inner fender well.
Old 09-01-2006 | 01:46 AM
i take that back you said its a 325 60r so that i believe is around a 31" tire, and that would fit perfectly, you might even be able to go to a 305 33" tire.
is your trucka 2x or 4x?
Old 09-01-2006 | 02:00 AM
Dr. Franko's Avatar
325-60-18 = 33.35
Old 09-01-2006 | 07:17 AM
kosnic's Avatar
Are you sure of the backspacing of that wheel, I've been looking at the wheel for a while have not found an 18 x 9 Moto Metal 951, with 6" BS.
Old 09-01-2006 | 08:58 AM
wandell's Avatar
Yeah, a 325/60-18 is basically a 33x13.00-18 tire. They will fit a 4x4 with a leveling kit using a 9 inch wide wheel with 5 to 6 inches of backspacing.
Old 09-01-2006 | 10:30 AM
Mange's Avatar
Thanks guys. Really leaning toward this setup.
