Rim and Tire Advise
Rim and Tire Advise
I recently added a 2.5 spacer lift to my 05 F-150 4x4.. When trying to make the decision on the wheels and tires size there are a ton of questions.
I was thinking about LT325/65R18... Also on the rim size, I want the tires to stick out just a bit, not a ton.. Do you recommend the rim width to be 8 or 9 inches???
Any comments or pics would be a huge help..
Also on tires would LT325/65R18 or LT325/60R18 be a better fit on the wheel well???
Thanks in advance!!
Thanks in advance!!
if youre going with a 325/65R18 (35") you need to find a rim with roughly 6" backspacing to get away with only minor rubbing- if you stick out much more, you're going to rub on your fenders left/right... if you want to stick em out a bit, a 325/60R18 (33") would be better as you should be able to clear your fenders on turns...
also, if you are going with a 35" tire you want a wider rim so a 9" wide rim sounds good
Thanks for the advice.. Now that I think about it 35' s are much too big at that size.. BalogUK - I do like that you fit 35's on your stock rims.. Looks good..
Wandell - In another post I asked about wheel offset..what kind of offset would I be looking at 325/60r18?? To get to what I think I want...
Soo many options..
Thanks!!!!
Soo many options..
Thanks!!!!
