Anti lock problem
Anti lock problem
Has any one had problems with their antilocks? My 99 F150 4wd had a problem with the antilocks comming on for no reason, I took it to my dealer and they replaced the module for over $700 dollars. As of yesterday the same thing is happening. I also have a 93 SHO that is having the same problem. Is there a problem with Fords anti lock system? Any help would be appreciated.
on
For the SHO, drop by www.shoforum.com and I'll be happy to help you out there. I posted instructions there on how to pull yout ABS codes on the SHO. Look for the sticky at the top of the forum that inclused the Brake system.
Steve
Steve
Let us know what you find out.
I recently pulled my truck out of storage after a year deployment to OIF. And it's doing the same thing that you describe.
Every once in the while the ABS light will come on. And then the brakes work normally. Almost makes me wish that what ever the problem was it would be bad enough that it would always trip the light.
Doug
Doug
I also heard an annoying ticking noise in the left manifold area and I thought it was an exhaust leak as well. It does not occur during cold start up but after I driven the truck and let it sit an hour or so. I suspect mechanic would recommend an exhaust manifold replacement and I was not mistaken he said I had mine cracked.
