'97 Brake and cruise control upgrade
Does anyone have experience and data related to putting disc brakes on the rear of my 2wd. I would also like to put ABS in as well.
Same here for installing cruise. I know that I can install the dealer kit, but not sure how that relates to the use of a c/control master cylinder. I would prefer to go to OEM and getting a list of the associated parts would be the perfect solution.
BTW, I have done all these before on other cars, just new to 150's.
Thanks a bunch
Dane
Thanks a bunch
Dane
911crash-
I just did a quick search for you and came across this. Take a look at this and there was a ton of threads about your question. Good luck and happy searching !!!
Rear Disc Conversion Kit
I bought a new (used) axle from the junkyard for $700 that came with all the disc brake components. I didnt have time to make it all work together, since I was after different parts, but I imagine if you could find a late model axle with all parts, it would save you a ton over buying a kit.
