rim question
Old 10-05-2006 | 10:24 PM
centfl150's Avatar
rim question
Would a 33x13.5 tire on a 10 inch wide rim with 5 inch backspacing -12 mm offset work on a 2000 f150 4x4 offroad? I'm not worried about trimming or sticking out. I am curious if this will rub the frame or anything because of too much backspacing?
Old 10-06-2006 | 09:00 AM
wandell's Avatar
It will be tight but it will probably work. I have seen a set of 18x10's (4.5 inches of backspacing) and 325/60-18 (33x13.00) tires on a stock 4x4 on Trucks! tv show.
Old 10-06-2006 | 10:41 AM
centfl150's Avatar
Ya, I plan on putting on a 3 inch body lift and leveling with the torsion bars. I just wasn't certain about the backspacing being too much even though its only 1/2 inch more than stock.
Old 10-06-2006 | 05:03 PM
wandell's Avatar
It should be fine. A lot of 17x9 inch wheels for our trucks use 5 inches of backspacing.
Old 10-06-2006 | 06:15 PM
centfl150's Avatar
Thats what im hoping . If the tire did rub the frame or whatever because of its width what would be the worst thing that could happen?
Thanks again
Old 10-06-2006 | 11:06 PM
wandell's Avatar
If it rubs the frame, it will probably just make an irritating noise or rub a shiny spot on the frame.
