Dull braking?
Old 10-28-2006 | 11:10 PM
skyyyz's Avatar
Dull braking?
My '98 F-150 sucks at emergency braking. "Dull" is the best word to describe response. Any suggestions? I don't mind spending more money for better braking. I've had new calipers, rotors, pads, rear shoes and rear wheel cylinders replaced.... still sucks.
Apparently I have only rear ABS. I can't seem to lock the front wheels no matter how hard I try. One would almost think I had 4 wheel ABS, but the dealer assures me that I don't.
What gives? I just ran over a wild animal because (at low speed) my brakes seem to lose about 40% braking power after the (initial) response. The dealer says they're "normal". I've never had a vehicle that stops so crappy.
Jay
Old 10-29-2006 | 09:10 AM
mgsalida's Avatar
I had a similiar situation with my wife's Pontiac Grand Am....."inherent soft" brake pedal feel, not too good stopping power. I put on a set of Bendix brake pads (titanium facing) and had her drive it. She thought I had rebuilt the brake system. The stopping was SOOOOOOOOOOO much better. You might try something along those lines if available in your area.
Mike
Old 10-29-2006 | 10:02 AM
Rikster's Avatar
Assuming there's no air in the lines, I have to agree that switching to a better brake pad will probably cure the problem. I never really cared for the OEM pads. They felt dull, just as you describe, practically from the start.
Old 10-29-2006 | 07:14 PM
skyyyz's Avatar
Hey guys, thanks. Mike, did you replace the calipers with Bendix too, or just the pads? I'll try finding them local.
Appreciate the advice.
Old 10-30-2006 | 06:20 AM
mgsalida's Avatar
No, I didn't replace the calipers, just the pads. You can find the pads @ Kragens or Auto Zone. The Bendix pads should have a MKD prefix in the part number.
Good luck
Mike
