Got My EradiSpeed Front Rotors
Old 01-25-2007, 03:26 PM
MeanGene's Avatar
Originally Posted by mwdhand
Hate to bump an old thread like this, but where's the review on these brakes now that you've had them for a while?
Also, will these things work with the 18" spare that comes with trucks that have 20's?
The brakes work very well. It does stop on a dime. Along with the Russell SS brake lines the brake feel is much improved. Most of the time I only need to use light pressure for normal stopping. I have more control over hard braking as well with the ability to confidently regulate near wheel lockup pressures. It feels like I'm driving a truck that is much lighter than it was before and I am still using the stock brake pads.
I don't think the 18" spare will work up front. So If I get a flat up front I'll just have to change two tires. A little more work. I wonder what a 20" spare would cost?
Old 02-13-2007, 11:26 AM
Quickerthanu's Avatar
Originally Posted by MeanGene
What I didn't realize and Baer doesn’t advertise well is what you get for your money. I talked with one of the technicians at Baer for a while and found out why it cost so much money compared to other brake rotor replacement kits. The stock rotors that come on our 2004+ F150's are one piece units that include the hub and wheel bearings. To make large, replaceable rotors and make them out of different (better) materials, they needed to be made in a two piece configuration rather than one big piece of cast iron. Because the wheel bearings are not sold separately you will need to press them out of your old hub and into the new Bear unit. Here are some pictures of the whole kit so you can see all that you get for your $600.00 and something dollars.
I won't be installing them for a couple of weeks, but I'll be sure to post my experiences then.
$600 & some change??? Where did you get them from?? The 4x2's kit I've found are $800+. (part# 2261029)
Old 02-25-2007, 07:04 PM
latinosgt's Avatar
MeanGene:
Where did you buy your rotors from because I have looking online and can only find them for 850+. I have a 05 F150 King Ranch with 22' rims that I want to upgrade my rotors on. Thanks.
Old 02-25-2007, 08:23 PM
MeanGene's Avatar
Sorry about that, I think I was quoting the 4x4 prices which are lower. The best price I have found was here. Which is in the $800.00 price range.
Old 02-26-2007, 09:56 AM
Wonder what the difference is between the 4x4 kit and the 4x2 kit???? Anyone know if the 4x4 parts OEM parts could be adapted to the 4x2 to just purchase the 4x4 kit and save a $100 or so between the two kits??
P.S. I also found the kit for a little cheaper........$800 something...http://www.performancecenter.com/pro...ORD/2004/F-150
Andy
Old 02-27-2007, 12:20 AM
MeanGene's Avatar
Andy
Yes, the difference is that the 4x4 is just the rotor and the 4x2 is a rotor and hub. The stock disc brake on the 4x2 is one large and heavy cast iron hub and rotor in one. The Baer kit provides an aluminum hub, bearings and a zinc washed cast iron rotor.
No, they cannot be adapted.
Old 02-27-2007, 10:40 PM
Dan99Hawk's Avatar
Hmm I`m suprised these work better. There`s more inertia to stop, and the braking surface area is the same since bigger or better calipers aren`t used...
I would think it would be a purely cosmetic mod.
Bear does make some really great stuff thou.. I had the 2 piece rotors on my Firehawk, they were a very quality piece.
The mushy feel of the F-150 brakes is kinda bad.. I~m hoping some braided steel lines will solve that?
Old 02-27-2007, 11:11 PM
anaheim_drew's Avatar
They use bigger rotors
Old 02-28-2007, 02:27 AM
ducati_800ss06's Avatar
nice
Old 02-28-2007, 03:39 PM
chester8420's Avatar
Originally Posted by ducati_800ss06
nice
You got that right. I'm sick of vibrating my teeth out every time I stop. Stupid crappy stock rotors!
Old 02-28-2007, 10:27 PM
MeanGene's Avatar
Yes, but because the rotors are two inches larger in diameter then stock they are clamping down on the rotor an inch further away providing the caliper a greater mechanical advantage and although there isn't any more pad surface area there is more surface area for the pad to use. I also installed Russell SS brake lines which provide a better feel.
Old 03-01-2007, 12:38 AM
latinosgt's Avatar
MeanGene:
Where id you get your Russell SS brake lines and what was the cost? You do the job yourself?
Old 03-01-2007, 09:33 PM
MeanGene's Avatar
Originally Posted by latinosgt
MeanGene:
Auto Parts Warehouse, they were hard to find. This is a three line kit. As far as I can tell there is no five line kit so the lines that go to the calipers on the rear stay rubber.
Old 03-01-2007, 09:56 PM
Dan99Hawk's Avatar
Makes sense to me
Old 03-02-2007, 12:44 PM
street3285's Avatar
Try this site to order Baer Brakes..... they have good prices and the guy is very knowledgable.
www.driverzinc.com
Quick Reply: Got My EradiSpeed Front Rotors
