Whats the Tallest tire I can fit on a 4x2 with the Truxxx 3" leveling kit. Im planing on getting 20" rims. I will also be adding a AAL in the rear. Thanks in advance!!
I wouldn't go higher than 2.5 inches with a leveling kit or you will probably wear out your ball joints quickly. You should be able to fit a narrow 33 inch tire like a 285/55-20 or 305/55-20.
TonkaTruck33
Im getting mine from a local dealer(Alamo Auto Supply). But I know that you can order it direct from Truxxx.com. Its a little more expensive but I need all the lift I can get! BTW Nice Truck!!!
