How to replace / swap / change brake caliper ...
Guest
Posts: n/a
Looking for some good links on how to do this. Pretty much, all I need to know is, once I get it down to the caliper free and hanging by the brake tube, what do I need to do? Can I just slide it off and put the new one on? I am sure I will lose fluid but I am looking for some suggestions. I have a 1995 F150. Thanks all. I will post pictures when I am done so it is archived here.
on
Click my signature link & look in the Brakes & Hubs album. Your truck has RABS & probably the later floating caliper design.
The quickest & easiest way to swap a caliper IMO is to:
1) set the front of the truck on jack stands & remove the necessary tire.
2) remove the banjo bolt from the bad caliper & transfer the hose to the new one.
3) pump the brake pedal to push fluid into the new caliper. Do not blow the piston out.
4) hold the new caliper so the banjo bolt is at the top & use a C-clamp or pad spreader to compress the piston & push any air back to the reservoir.
5) remove the bad caliper & install the new one.
6) test the brakes & bleed as necessary.
Guest
Posts: n/a
Whew, didn't need to replace the caliper. However, I noticed part of the pad , about a 1/2 inch chunk flaked off and this caused more of the rotor to be exposed and rusted. Should I re-surface the rotors or will the new metal pads take care of that for me? I really don't want to take them off as I have auto-hubs and they are a PITA!
Originally Posted by Steve83
Many shops now have on-car brake lathes, .
on
Ford actually recommends turning rotors on the vehicle now because it produces a truer surface. And for '80-96 trucks, it's MUCH quicker than removing the rotors. Ours mount to the BACK of the hub, so the hub has to be removed from the spindle to get the rotor off. It's a VERY drawn-out process, especially on 4WDs.
Guest
Posts: n/a
Thanks all for the reply. Yeah, removing the rotors just isn't what I like to do on these 4WDs! I'll call around too see who does this. Thanks alot all for the replies.
Edit: How much do you figure on car brake lathe service would be for the front rotors? I am seeing around 70 dollars!
