What backspacing to use with 6inch procomp and 37x13.5???
Finally I got some stuff. I got a 6in pro comp lift, 3in Body lift, 305/70R17 Maxxis Bighorns mounted on 17x9 mickey thompson classic locks (mounted/balanced ready to go), front and rear 4.56 gears w/ master install kits, rear gap gaurds (Can you buy just the front ones?), and lugs, center caps, and a few misc things like a truck cover, ect. I bought all this stuff from a guy who bought it all and never got around to installing it. Most of it was not even opened.
All I need now is the truck, lol, I got a 2x4 now, but hopefully I'll have enough for the 4x4 within a few months, and then I'll already have all the stuff to put on it. This deal was to go to pass up.
Anyway, I plan on selling those Bighorns/and classic locks(If your interested in them check out the classified section) and getting some 37x13.5's on 17's.
I have a few questions though. First of all what back spacing should I use? I know the procomp doesn't allow more than 5in. I was thinking 4.75in or 5in? What do you all think?
Also does anyone know what backspacing this truck is using?
https://www.f150online.com/galleries....cfm?gnum=6175
I think they only make those rims in 4.75? Is that right?
Also does anyone know if I will have any rubbing with this setup? It seems a little tight on the truck in the picture, would there be more room on a 4x4 truck? I know 4x4's are 2in taller, does this extra 2in remain after the lift?
I am planning on getting a 4x4, to put all this stuff on, so it should clear better than the one pictured. I looked up those rims in that picture, and I think they only come in 4.75in backspacing is that right? I would think 4.75 would stick out more than that? I have read that with the procomp you cannot go more than 5in backspacing cause the rim will hit tie rods is that true?
