ok so moto metal 18x9....wandall please advise...
Moto Metal 951 one piece chrome plated aluminum wheel. +30mm offset and 4 1/2" backspace and a 2" AS leveling kit. will it rub. i know im supposed to be shooting for 5" or more backspace but i cant find anything i like with it. what does the offset -12mm or +30mm have to do with anything? again im a total truck/wheel newbie. thanks
THey should fit with a set of 33 inch tires if you have a 4x4. I believe several members have the 18x9's with the 4 1/2 inches of backspacing. Personally, I'd get the ones with 6.1 inches of backspacing, but it depends on the look you want. I'm just impressed they off the same wheel with two different backspacing/offsets. You may have to do some trimming if you go with the ones with 4.5 inches of backspacing. Also, offset is just another way to measure how far a wheel will tuck/stick out.
i put the 18x9's with the larger gackspacing (the one that sticks out more/has a deeper dish) and i put the AS2.5 kit on.. i did have to trim the front valence, but it was MINOR.. only like a 1/4 inch max.. and it was just the corner.. u cant even tell it was cut, and it doesnt look diff at all.. but i got the wheels in black.. and either way, chrome or black, the wheels look sick as hell. very happy with them..
and if your lookin at tires too.. i recomend the nitto TG's.. 325/60/18.. since i out them and the leveling kit on, my truck actually rides bette rhten it did before!.. no joke. and its a good tire.
let me know if u need any info, i have been sayin im gunna post pics for a week now, one day this week i will.. for sure
-david
-david
More backspacing means the wheels tuck in more. Less backspacing means they will stick out more.
You are right. That is the problem, finding the perfect compromise between rubbing on the frame, sway bars or ball joints and sticking out to far and rubbing on the fenders and bumpers.
