nitto 295 70 17
To you guys running the 295 Terra Grapplers, what rims are you running them on and how do they fit?
I'm asking because people have told me a 295/75/16 (which is basically identical to your tires) might rub on a 2000 F150 4x4. I would be putting them on some new 16x8s. How do the tires fit for you guys? Would you go with 285s if you were me? Thanks for the help.
Sounds good Matt. I've heard that the 295s fit alright on the stock 7.5" rim. So I'm assuming they would fit fine on my 16x8. The stockers have 4.5" of backspacing and my wheels have 5", so I don't see why they wouldn't work. If all else fails, I will just settle for the 285/75/16s (33x11.5).
Yea I figured that the 295s would fit fine. They come out to being about 33.6x11.7 on the tire calculator. Here's my basic reasoning:
The 295s are less than an inch taller and half an inch wider than the 285s. People fit the 285s EASILY onto stock 4x4s, so why wouldn't the 295s fit?
Anyone else runnign a 295 tire please chime in...thanks for the help.
Thanks for all the replies. I know it seems I'm beating this subject to death, but I'm on limited funds right now. The last thing I need is to buy a set of tires that is too big and won't work. Based on your guys opinions and others' trucks, I guess I will go with the 295s. Any other opinions would still be helpful. Thanks for all the advice.
