97 2WD Front Caliper pin grease
Old 02-26-2007 | 01:08 PM
dennisinmo's Avatar
Will the blue wheel bearing grease work for the caliper pin grease?
I had a caliper stick and ruined the outside brake pad. I usually use the grease you get in the little foil packs but I now have a new can of blue wheel bearing grease. Thanks
Old 02-26-2007 | 04:41 PM
Colorado Osprey's Avatar
Any grease can melt under heat and get into the brakes...the correct lube for the slider is silicone caliper lube....a little goes a long way. I've seen lithium used though...personally I just stick to caliper lube.
The blue grease is just anti-water grease....or marine grease.
Old 02-26-2007 | 05:32 PM
keith97xlt's Avatar
any high temp grease will work. it will say high temp right on the container
Old 02-27-2007 | 09:23 AM
2001XLTSilverSport's Avatar
Exclamation
I found that Lubegard makes brake caliper grease. It's silicon grease with molybdenum disulifide and has a wide temperature range. I searched the internet for brake caliper grease and this one appears to be the top of the line. And its $5.50 for 3 oz tube. I found it for sale online at this link
http://www.transmissionpartsusa.com/...Show=TechSpecs
Here's a Lubegard link.
http://www.lubegard.com/automotive/b...pergrease.html
I bought a tube but haven't used it yet.
Jerry
Old 02-27-2007 | 10:04 AM
kingfish51's Avatar
You can use high temp di-electric grease, which is what Ford uses. Do not use regular grease. All it does is attract dirt and moisture.
