biggest tirers
biggest tires on 97 f150
i have a 97 f150 with 17" rims and i want to put bigger tires on it. what is the biggest size that will work without rubbing? i also found some tires online with these dimensions. i also found a website that says the maxium is 265/70/R17
Tire Width:
315
Aspect Ratio: (if that matters)
70
Diameter:
R17
will they work?
Tire Width:
315
70
Diameter:
R17
will they work?
True... 315/70/17 is a 35" tire and will probably looked a little stuffed with out a lift of any kind but will fit with some rubbing at full steering lock. I'd go with some 33x12.5's (305/65/17) if I were you. So far as 265/70/17 being the largest tire you can fit...thats B.S. I've got 33x11.5's (285/70/17) on my '97 4x4 and I havent got a problem in the world. No rub what so ever. Do you have a 4x4 or 4x2?
I tightened my torsion bars up for the same reason. I wanted the truck to sit level.
I want to say that you wouldnt have to trim anything on your truck. If anything, your front valence just a little. If you want the bigger tire, I'd go with the 35's. If you do get the 35's, post pics. I'd be curious to see how they look.
