Backspacing
Backspacing
okay i am going to either get a 2" or 2.5" AS leveling kit. I have 20x8.5 wheels with 6" of backspacing. I would like to get the bigget tires possible with the leveling kit and i would ideally like to have the tires stick out about 1-2 inches outside the truck when looking at it from the front..what backspacing do i need to have to get the tires to stick out??
I didn't realize you had OEM 20's. I think they may be a little wider than the OEM 17's and 18's but I believe the backspacing is the same. The more backspacing a wheel has, the more it will tuck in. The less backspacing a wheel has, the more it will stick out. Generally, wheel spacers are not considered a great idea, but a few members here and at FTW have used them with no problems.
awesome thanks wandell. i think that is what i will go with, i will just check with some local tire shops and see if they think it will fit too. any ideas as far as tires? im looking for a mud terrain for summer driving beacuse the tires i have on right now are going to be my winter tires
