stock vs.33's and AS
Old 04-03-2007, 01:08 PM
Dan in MA's Avatar
Question As
Where is the best place to get the AS leveling kit ? Does it void the Ford warrenty in any way ? I have 3.55 gears with LS, how will 33's affect my milage and power loss.
I love the side by side pictures you guys posted for comparison. I think you made my mind up too.
I keep telling the wife that 2.5 inches is a good thing.
,Dan
  #32
Old 04-10-2007, 09:50 AM
NCSU_05_FX4's Avatar
Dan, http://motors.search.ebay.com/_W0QQf...ssZsprngbender is the place to get the AS leveling kit. 33's shouldn't affect your milage or power too much, but with 3.55 I'd stay away from 35s.
I've got 275/65/18s on now which are 32s and I average 13-15 MPG, mostly city driving. I'm also running the 93 octane max performance Troyer tune
  #33
Old 04-10-2007, 02:23 PM
cannonballgsu's Avatar
wow...i'm running 325/60/18 Mickey Thompson ATZ's with S&B intake and Superchips highest setting, and get 14.5-15mpg b/w city and hwy driving
  #34
Old 02-18-2008, 03:08 PM
smokester06's Avatar
Originally Posted by roloplex
I just took a picture of my friends stock 4x4 and mine with 33's and 2.5 AS. This should help alot of people make up their minds about the AS. HUGE DIFFERENCE
I know this is an old post, but I had saved it quite a while back because I am interested in doing the same thing with my truck. Have a couple questions for you if you don't mind.
When you switched from stock to the larger tires, did you also change the gear ratio and/or did you do any research into it? Just curious to know what this does to the transmission if you don't change the gear ratio.
I added 2" leveling kit to the front of mine. Do you know if this would be sufficient clearance to avoid any rubbing if I went w/ 33s? If not, what's the largest I could go with, do you know?
  #35
Old 02-20-2008, 09:47 AM
davewvu86's Avatar
How many inches taller then stock do you sit (highest point)? I'm thinking about a 2" with some 33's on my 2005 Supercab but I'm not sure if I'll still fit in the garrage at work.
Thanks!
  #36
Old 02-21-2008, 09:52 AM
JMBdevotee's Avatar
Originally Posted by davewvu86
How many inches taller then stock do you sit (highest point)? I'm thinking about a 2" with some 33's on my 2005 Supercab but I'm not sure if I'll still fit in the garage at work.
Thanks!
I would like to know as well. Thanks!
  #37
Old 02-21-2008, 10:20 AM
towrig06's Avatar
I know with my 2.5" AS and my 1.5" AAL with 295/70/17 tires my truck is sitting about 4" higher. I measured the top of my truck the other night for someone else on here for the same reason. To the highest point on my truck it measured 78 5/8" tall.
Quick Reply: stock vs.33's and AS
