BFG 285 -65 x 18
BFG 285 -65 x 18
Does anyone have what these tires translate to in inches? They are the biggest Tires Plus sells for an 18 x 7.5" rim and i am going for the all powerful Daystar 2.5" lift as well. My truck is a 2wd as well, so i may block the rearend to keep it from looking like a reverse stinkbug
Man! my truck is black too ! what a perfect response!
Only difference is your bed is a little bit longer than mine --- my truck is a Supercab, but has the stubbed off 5 1/2' SCREW bed on it
Its rare to see a lifted 2wd (or any 2wd) in CO -- are you originally from Cali. ?
BTW --- did u notice any difference in your EDGE system from stock?
Guest
Posts: n/a
As for the Edge, probably still my favorite mod. With the larger tires I am a bit slower off the line, but I was expecting that. If you want I was going to wash the truck on Sunday if the weathers OK, I can shoot a better pic of the tires/spacer if you like.
