What Ever Happened To 80 Series Tires
I've been looking for some taller tires for my 06 scab 4x4 cause i got the 4.10 rearend and the 245/70/17 keep my rpms up at cruising speed. So i figure a taller tire would help some. I dont want to get new wheels right now, (not to many choices when you have the 7 lug bolt pattern) so i'm trying to find tires that would fit my stock wheels. Now i remember back in the day, 10-15 years ago you could get 80 and 85 series tires. they wouldn't be as wide but you could get the height. What happened! Is no one selling these anymore?
http://www.toyo.com/docs/tires/tires...=lgt-suv-truck
Look at the M-55 and Open Country H/T. I know those two tires come in the size 235/80/17. I think a few other toyo tires come in that size and 235/85's for 16" rims.
Michelin makes a couple of tires that are 235/80/17's as well. Just have to look around...
Originally Posted by lastorms
A 235/80/17 comes out to about the same height as my stock 245/70/17. I think I'm looking for maybe a 265/80/17. Alittle wider and taller. Should be about the same height as an 285/70 17, but will fit better on my stock wheels
235/80/17's are the same size as 265/70/17's, taller than your 245's by over 2 inches in diameter.
I have Michelin 235/80/17's on my truck, which are 31.8 inches in diameter, vs the OEM 265/70/17's (on 4x4) which are also 31.8 inches.
http://www.michelinman.com/specs/ltx_m_s/27.html
The 285's would fit fine on your truck. You could even go up to the 35' range with a leveling kit if you wanted to. But I understand if you dont want that wide of a tire (not to mention the price). I have the 285/70/17's on my truck right now. You can't go wrong with that size. Sorry I wasn't more help.
Ok, I'm mistaking. Didnt think it would be that much of a difference. But 235 is a narrower (sp) tire. I want to keep at least the same with i have now, just taller to fill in the empty space. Just dont think i'm gonna find what i want
Dont discount the fact that they (235's) are narrower. My truck handles so much better with them, that I would not ever consider going back to 265's. Better gas mileage, E load rating, smoother ride, smoother steering, etc... They really don't look that funny on a half ton either.
Ahh... I see what your asking for now... I guess I wasn't that into tires 10-15 yrs ago because I've never seen that size before.
Do you have pics? My truck is sooo big now that the tire i have look small
For purpose, and utility, I say go for the 235/80's, if you want looks, to sacrifice purpose and utility, go with the 285's. I will say if you are mostly interested in towing/ hauling, you will not be too happy with the performance lost with the 285's.
Here, wait a minute, found a pic in my gallery with my summer tires, before I switched them over... not the best to see what you are looking for, but...
