36/14.50/20 tire pressure??
I have a set of dirt grips 36/14.50/20 mounted on some 10" wide rims. I believe the pressure in the tires now is something around 35-40 and they dont seem to be wearing on the side lugs. The load range is D on the tires and I think its a max of 65. I have searched and I have seen its around 40-45 that most people are saying but they were all on a slimmer tire. I know its a big and wide tire but I still want to squeeze as much life out of them as possible. Also if I do a chalk test what it the lowest pressure I can safely run if 40 is still to high? By no means do I want to sacrifice safety.
The max pressure on the sidewall is 50 not 65 like I said in my first post. Would 45 still be a good pressure? Thanks for your help Kingfish you seem to be the "tire pressure" guy from all the responces to other people that I have seen in my searches. I didnt know if the width would have a effect on the tire balloning in the middle or not. I just wanted to check cause I didnt wanna wear out 1500 dollars of tires any sooner that I have to
Don't know that I am the "tire pressure" guy, but have had different load range tires on many different F150s, and have had good results with these pressures. Minimum miles I have gotten out of any tire is 40k.
the tires are a D load rating...it says on the sidewall...i have the pressure at 40 now
What is the max load at 50 on those tires?
3085 lb.
Just a update on my tires. I have 40 in the fronts and the rears to 37. The fronts are prolly leaving one half to three quarters of a inch on both sides untouched. The rears were worse thats why I lowered the pressure but im not sure how much if any it helped. I have a 14.50" wide tire on a 10" wide rim and also its on a 20" rim so im thinkin it just might not have enough sidewall to let everything flatten out.
