Does it take a while to stop?
Old 03-30-2007 | 08:09 PM
domM's Avatar
I have a 97 F150 super cab and It feels like it takes a while for it to come to a complete stop. Do I need new brake or brake pads. Alot of my buddies have Chevis and GMC and they dot have this problem
Old 03-30-2007 | 08:13 PM
F151's Avatar
Could be... pull a wheel and find out.
Old 03-30-2007 | 08:19 PM
domM's Avatar
could be that I need new brake pads? When I looked though my rims the brakes look rusted. Is this a sign?
Old 03-30-2007 | 09:17 PM
InstantGrits's Avatar
If the rotor looks rusted that brake is not working properly. The pad will clean the rotor when it rubs on it to stop. From the sound of your post you need to take it to a mechanic and let him/her fix it.
Old 03-31-2007 | 07:22 PM
keith97xlt's Avatar
its a 97 so you probably have rear drums. check and make sure they are adjusted correctly. that can affect pedal travel.
Old 04-02-2007 | 11:37 PM
99Txtruck's Avatar
Let's grab the snake from the head...
I agree with Keith, a 1997 F-150 has rear drums. if your rear brakes are out of adjustment, it will decrease your braking performance, since the fronts are doing all the job.
Check the rear brakes for play and/or wear. Does the parking brake hold the truck? Does it sink all the way down? If the answer is yes, you need to adjust the brake shoes.
Hope that was helpful!
https://www.f150online.com/galleries....cfm?gnum=7516
Old 04-04-2007 | 01:24 AM
domM's Avatar
yeah it holds my truck and it goes down all the way.
Quick Reply: Does it take a while to stop?
