Will 33x13.50r20 fit a 06 4x4 with just a 2.5 level kit?
I have a 06 4x4 and I am thinking about getting a set of Moto Metal 951 20X10 with 4.5 backspacing and some MT ATZ 325x50r20(33X13.50R20). And I was wondering if only putting a 2.5 level will be enough clearence for that wide of a tire and wheel. Please help I am ready to pull the trigger on this project.
Originally Posted by quickie4x4
check my gallery. I had 33x13.50 r20 with just a leveling kit. They will fit fine if you get the proper backspacing. Mine stuck out a bit so they rubbed a little bit at certain points. Just needed a little trimming. Pics in my gallery.
Quickie4X4,
What would be the proper backspacing for the 20X10 MotoMetal like yours?
FYI the pic in my sig has 33x13.50's with an 18x9 motometal951 with the 4.5" of backspacing. with the 6" of backspacing the wheel won't look deep at all
edit: here is a better pic, the only thing different you will have is the profile of your tire and a taller wheel
and by the way, the back don't stick out that much, its on an incline
....to be quite honest, I am not sure. I ordered mine through my local 4wp and assumed that they were wise to what they were doing. It worked out well, like i said, just a little plastic trimming and it was all good. No major cutting. I would hate to tell you incorrect backspacing. Check 4wp http://www.4wheelparts.com/PPT5300T100100.aspx and if i were you I would go with the 20 x 9. Those look like they would be a perfect fit for what you want to do. If you were in Phoenix I'd sell you mine for a deal so I could go buy some Black Rockstars!
Had the same setup, but in a 18" rim.
