Lift new tires and gears on my 2001 Screw King
Old 04-03-2007 | 11:16 PM
KingRanch's Avatar
Looking at doing a lift, new tires and gears on my 2001 Screw King.
Can any one tell me how big of tire I can put on the stock 17” rims? How wide are my rims 8”?
After I figure out how big of tire I can put on my rims then I will need to know how high I need to lift the truck to get the tires under it, and what to use to lift the truck.
After that I will want to change the gears in the differentials. I want to be running about 2700 to 2800 rpm at 75 mph. With a limited slip in the front or some kind of locking front differential.
I am sure someone out there has done this a time or two that can help me make this Screw King climb and go through the sand and mud.
Old 04-04-2007 | 02:41 AM
MattDickson's Avatar
biggest tire you can do on a stock rim is 35inch...and ur rim is 17x7.5...im sure more people will chime in...
Old 04-04-2007 | 01:04 PM
wandell's Avatar
Right. I'd suggest going with a 6 inch Fabtech or 5 inch RCD lift with a set of 35x12.50 tires on a 16x10 or 18x10 inch wheel.
Quick Reply: Lift new tires and gears on my 2001 Screw King
