Help me pick my package
This is what the wheel/tire place said:
These wheels have a +14mm offset. That is more than normally used with a lift kit, but it all depends on the lift kit itself as to whether or not you will have any issues. I would check with the manufacturer of the lift kit and see if they think a 20x8.5 wheel with 5.25" of backspacing will work. The typical backspacing with a lift is 4.5" to 5", so these are just outside of the norm. and should work as long as your lift doesn't drastically change the angle of your control arms.
