Toyo MT 33x12.50R20 and wheels
I have a 05 F-150 4x4 with a 2.5" leveling kit on and I am about to order some new tires and wheels. I need to know if this setup will workthat I am going with
Toyo 33x12.50R20 MT Tires
20x10 -21 offset and 4.6 backspacing wheel
How far wil this stick out and will there be any rubbing
THose wheels are gonna stick out about 3.5 inches farther than the OEM wheels. You will have some minor rubbing and will probably have to do a little trimming to cure it. THey will work, but just be aware of what you are getting into. I think a 9 inch wide wheel, or a 20x10 with more backspacing would be a better choice personally.
It will depend on the backspacing of the wheel. If you go with a 10 inch wide wheel with 4.5 inches of backspacing and a 12.50 inch wide tire, you will have to trim. I'd try to stay with a 9 inch wide wheel with between 5 and 6 inches of backspacing (depending on the stance you want) and a tire that is 305mm (12.50 inch) or 325mm (13.00 inch) wide.
