Best 20in rim tire set up?
Old 04-15-2007 | 12:00 AM
chanco79's Avatar
I am installing leveling kit on my 05 F150 supercrew. I want to get 20 inch KMC rockstars. What are the best size rim and tire combo? I really don't want to rub, but want to get most tire I can! Anyone have pics of that set up? Will the Toyo 33x12.50 fit? Decisions, Decisions!
Old 04-15-2007 | 10:19 AM
wandell's Avatar
If you have a 4x4, you will be able to fit those tires. How much, if any, you rub will depend on the width and backspacing of the wheel. What are the specs on the Rockstars?
Old 04-15-2007 | 12:06 PM
chanco79's Avatar
20x8.5 with 5.1" Backspacing (+10 Offset) are the specs on the rims. Are they to close to the stock 20's. What would be the best 20 in combo to get as much tire in the well as I can and as wide as I can with out rubbing. I saw that combo on another f150 and the tires didn't stick out that much. I want them to stick out a little....Thanks
Old 04-15-2007 | 04:24 PM
wandell's Avatar
Yeah, the OEM 20's are 8.5 inches wide with 5.5 inches of backspacing. Those will fit fine, especially if you install a leveling kit.
Old 04-15-2007 | 06:25 PM
chanco79's Avatar
Will they stick out more or less then the stock wheel with the 5.1 backspacing? Would I be able to go 20x10 without rubbing?...Thanks
Old 04-15-2007 | 09:14 PM
wandell's Avatar
They would stick out about 4/10 of an inch more than a set of OEM 20's. They will stick out about 1 1/2 inches farther than the OEM 17's and 18's. You can use a 10 inch wide wheel, but you will probably have to do some trimming, depending on it's backspacing.
Old 04-16-2007 | 07:05 PM
SCREWedUPnUTAH's Avatar
Here is mine 20" moto 951 with 35" procomp xtreme mts. Just a leveling kit.
Old 04-16-2007 | 07:38 PM
skid212's Avatar
SCREWedUPnUTAH,
What size are your tires? Do you have any other pics?
Skid...
Old 04-16-2007 | 07:45 PM
chanco79's Avatar
Hey SCREWedUPnUTAH what size rim and tires are they? Thanks
Old 04-16-2007 | 10:47 PM
mt_b8's Avatar
I don't think they offer the Rockstar's in 20x10 for the 6 on135mm bolt pattern.
Old 04-16-2007 | 11:08 PM
chanco79's Avatar
Then I will have to go with the 20 x 8.5 KMC rockstars or I just saw taht ION style 185 has 20 x 9 and looks like rockstars. So my question is what is the maximum all around tire can I go with....Is it the 33x12.50???
Old 04-16-2007 | 11:18 PM
mt_b8's Avatar
Do you have a 4x4 or 4x2? You can fit the 33x12.50 on a 4x2 with the stock wheels and 2.5" level kit, with an aftermarket wheel you will need the backspace to be as close to 5.5" on the 20X8.5 Rockstar, or 6" on the 20x9 ION. If you have a 4x4, you can fit up to a 35x12.50 on the stock wheels.
Old 04-16-2007 | 11:24 PM
chanco79's Avatar
Its a 4x4 with 2.5 leveling kit. I don't want to stay with the stock wheel because it is a 17in and I want to go with 20inch. What is the best size I can go with those aftermarket rims? I want it to stick out a little bit. The lower the backspace the more it will stick out? Is that correct? The 20x8.5 have a 5.1 backspace.
Old 04-17-2007 | 12:59 AM
mt_b8's Avatar
Those rims will stick out .5" farther than the stock 20's, I'm not sure how much further than the stock 17's. .5" farther than the OEM 20's will bring the wheel out to the fender, maybe a little past. As far as tires, I would stick with a 305/55/20( 33x12.50).
Old 04-17-2007 | 07:54 PM
5.4 LARIET's Avatar
I have 20x10 on my truck with 305-50-20 nitto's. Rides great.
