Nitto M Grapplers on Stock wheel 2WD
Old 04-24-2007 | 10:54 PM
Foxacrombie's Avatar
I have a 2.5 leveling kit on my 04 Screw 2WD. Will Nitto Mud Grappler 33x12.5 18R fit without rubbing? I know 33 AT's usually fit but I'm concerned with the aggressive side lugs, that there might be some rubbing. Anybody out there have this set up? Also, anybody know what is usually the going rate for labor on a 3" body lift installation?
Old 04-25-2007 | 01:20 PM
wandell's Avatar
They will probably fit fine if you use the OEM wheels. You will probably have some minor rubbing on the control arms at full steering lock.
Old 04-25-2007 | 01:48 PM
Thanks Wandell, you da man!
Quick Reply: Nitto M Grapplers on Stock wheel 2WD
