Need Urgent wheel Help
I have a 2007 5.4L SCrew Lariat 4x4, which I have installed a AS 2.5" leveling kit. I purchased a set of Toyo Open Country MT 35/12.50/R20, I am having trouble finding the right wheel offset to work without causing major rubbing. I messured the spacer above the coil and it measured 2". I plan to call the company, which I purchased the leveling kit from tomorrow morning to verify that they did not send me the wrong lift. Anyway, what wheel dimensions do I need to make the tire fit properly?
Yeah, most people running 35's with just a leveling kit are using the OEM wheels which are 7.5 inches wide with 5.5 inches of backspacing. If you use an aftermarket wheel, it's gonna have to be really, really close to those specs.
Also, leveling kits are measured by the amount of lift they give, not there actual height. The 2.5 inch AS lift is not 2.5 inches thick.
