How does a larger tire affect the speedo
This is probably a ridiculous question for most to read, but I am changing from a stock tire to 35" Pro Comps. What can I expect as far as the speedo and odometer accuracy? Will I actually be putting more miles on the truck and be travelling quicker than what the speedo reflects?
I believe that the percentage change in tire height would also be the percentage of error on the speedo. i.e. if your new combo is 10% different in height your speedo will be off 10% as well.
http://www.discounttire.com/dtcs/infoTireMath.dos
Buy a new speedo gear. VERY VERY VERY easy to change out.
One nut and the whole assembly pulls out. Pull off the C-clamp in the gear, slide the new one and bam. Corrected speedo.
Where I bought mine:
http://www.transmissioncenter.net/sp...n_______va.htm
Interesting related topic....
When I had my stock rims and tires, my speedo was 3-4 MPH faster than my GPS was reading. I don't know about anyone else, but I would trust the speed on the GPS before I would the ODO. When I went up slightly in tire diameter, the two are now reading within 0.1 to 0.3 MPH difference of each other. Go figure.
![Confused](https://www.f150online.com/forums/images/smilies/confused.gif)
When I had my stock rims and tires, my speedo was 3-4 MPH faster than my GPS was reading. I don't know about anyone else, but I would trust the speed on the GPS before I would the ODO. When I went up slightly in tire diameter, the two are now reading within 0.1 to 0.3 MPH difference of each other. Go figure.![Confused](https://www.f150online.com/forums/images/smilies/confused.gif)
On changing the speedo gear, didn't they switch to an electronic system around 1999? I guess once they made the change you have to buy a programmer for like $125.
