Brake Questions
Brake Questions
OK, I am going to replace my stock tires with some larger tires, but keep the same wheels. I have the stock P255/65R17 Continental Contitracs on now. I want to go to a P285/70R17 and still use the factory wheel. I understand that when I increase the size of the tire, I may need to increase the size of my brakes. Also, I want to go to either a ceramic or semi-metallic pad in order to eliminate the brake dust. I understand that ceramics don't have the stopping power of metallic brakes. Finally, I need to be able to safely tow 6500 pounds.
My questions are:
1) What brake pads will eliminate the dust and still stop my vehicle safely when towing?
2) Do I need larger brakes/rotors?
3) Please recommend specific manufacturer/part numbers and let me know where to order them from.
Thanks in advance!
My questions are:
Thanks in advance!
My questions are:
Thanks in advance!
My questions are:
Thanks in advance!
2.) I have 285/70/17 Nitto Terra Grapplers on the OEM wheel and all OEM Brake related components and have plenty of stopping power (and dust).
You don't need bigger brakes for that tire and wheel combo
