Tires for a better ride, tire guys??
#31
Originally Posted by APT
I have the BFG AT KO w/ 40k miles. Tread looks half worn. They suck in the snow compared to the Revos I had on my last truck. There aren't enough sipes and the compound is too hard.
FYI, the BFG AT LT265/70R17 Load C has lower laod rating, rides stiffer, and less on-road traction than some p-rated tires of the same size.
As for snow, never been stuck with the BFG, except when the packed snow lifted the body of the truck.
This is straight off the LTX web page.
* Passenger sizes used in Light Truck/SUV applications have reduced load capacity. This will differ from the maximum load branded on the tire sidewall.
#32
Kingfish,
I saw that warning re: p tires and load rating on trucks, but didn't understand how load capactiy would be different on a car vs. a truck.
ANYWAY, I BOUGHT TIRES!
Went a different way than what I was talking about with the Michelin MS's.
I wanted an all terrain tire but with the best ride I could find
which was the whole reason I was buying new tires. Went to tire track and looked at their ratings. Chose the Firestone Destination as it had the highest rating for comfort of all AT tires and was rated high in other areas as well. The tread design was less aggressive which I thought would add to it's comfort level and felt it was aggressive enough for me since I really don't do any off roading but do occasionally need something to get me out of construction sites. It was a less expensive tire @ 146.99 ea. much cheaper than the Michelins (which I'm sure is an excellent tire). 265/70/17 rated at 2535lbs max load. 44 lb max PSI. heavy enough to handle any thing I might be hauling/pulling with the truck over short distances. There is a notable difference in ride over my old 245/70/17 load range E tires. They seem to handle fine. I think the Bridgestone Dueler AT Revo would be an excellent tire as well. Built like the Destination by Firestone but with a different tread pattern. Ranked very high in all areas. The only reason I didn't buy those was because of comfort level (slightly less), and price. They were 172.99 ea.
This whole tire purchase thing for me was somewhat of an experiment to see how much tires would improve my ride in my heavy duty half ton, so I didn't want to NOT go with a tire that wasn't rated highly in the comfort area, than always wonder if I could have gotten a better ride if the ride wasn't markedly improved. I am happy with my purchase. My truck feels like it now rides more like a truck instead of a lumber wagon. From here if I want to try and obtain an even better ride I can, maybe try different shocks, or even play with the springs. But I feel the tires made about as big a difference as anything else could have. I actually enjoy driving my truck now. So if anyone is wondering how much of a difference tires can make it ride quality, I can say significant.
Figgy
Figgy
#33
Originally Posted by figgy
Kingfish,
What you purchased is considered a P series extra load. Max psi of 44. You will probably want to keep them near 35-40 range. I would not go lower than 35. Just keep an eye on the tread wear to see if you need to go higher or if you use nearer 40, go lower.
