Bolt pattern
6 on 135 mm its just a matter of looking it up on here or anywhere else online nowadays - unless you have the heavy duty package (7 lugs) all the new body styles are 6 on 135. we have the same bolt pattern as the expy's too - if that helps in your search, it did with me back in the day.
thanks ziggaboo
http://www.discounttire.com/dtcs/infoBoltPatterns.dos
Measuring your Bolt Pattern
Measuring the 4, 6 and 8-bolt patterns: They are measured from the center of one lug hole to the center of the opposite hole.
Bolt measurement examples
Measuring a 5-bolt pattern: A 5-bolt pattern is very difficult to measure without using a bolt pattern gauge. Basically, you would measure the diameter of a circle that crosses through the center of the lug holes. This method is not recommended to confirm wheel fitment.
