which of these 3 sizes will fit best?
Hello,
I have an 07 SCREW 2wd with a 2.5 AS lift. I have choosen to go with the MM 951 wheel, but I'm not sure which back spacing will work best. I will be running 285/60R18.
18x9: 30mm offset: 5.18 BS
18x9: 30mm offset: 6.18 BS
18x9: 18mm offset: 5.71 BS
They will all work, it just depends on the stance you want. The 18x9 with 6.18 inches of backspacing will stick out almost an inch farther than your OEM wheels. THe 5.71 backspacing model will stick out about 1.5 inches farther and the 5.18 inch model will stick out about 2 inches farther.
