new tires and wheel but....
Old 05-15-2007, 12:28 AM
marcorlando's Avatar
Hi,
after looking measuring and many other factors I decided to go with a fabtech performance 6" lift with rear dirt logic shocks. This is for a 4x4 04 new body style.
Now to the question:
I really like these tires and wheels XD 778 Series and Mickey Thompson Baja Claw Radial.
The wheel is a: 18x9, 6 on 135 / 6 on 5.5 Bolt Pattern; Back Spacing = 4.52 in.; Offset = -12 mm.; Hub Bore = 106.25
and the tire is a: LT325/65R18; Load Range = E; Max Load = 3860; Tread Depth = 23/32; Overall Diameter = 34.9
Do you think this would fit with the lift?? if possible with out any rubbing, in case there will be some, I will just shave something.
the kit is on this link:
http://4wheelonline.com/Products.asp...roductID=71904
THANK YOU, VERY MUCH ON WHO IS GONNA HELP ME!!!!
Old 05-15-2007, 12:37 AM
chumFX4's Avatar
Should fit no problem. Lets see some pics when you get 'em!
Old 05-15-2007, 01:39 PM
do you know if it will still be fine if I go with
Toyo Open Country AT LT325/65R18
Cuz I heard the mickeys r too loud and they dont last to long
Old 05-15-2007, 04:02 PM
wandell's Avatar
Yes, it should be fine. Just make sure you get your bolt pattern, which is 6x135mm (not 6x5.5 inches).
Old 05-15-2007, 11:58 PM
1 last question chumFX4 or wandell plz.
I just saw that there is to different offsets for the wheel that I want.
one is -12mm and the other is 18mm.
What is the difference?
Thank you,
very much
Marco
Old 05-16-2007, 07:19 AM
95'F-150's Avatar
I'm not 100% sure but pretty sure that a negative offset will make your wheel sit out from the fender. A Positive offset keeps it tucked under the fender.
Old 05-16-2007, 12:16 PM
wandell's Avatar
Right.
Old 05-16-2007, 03:27 PM
so, I guess I'm gonna go with the -12mm
Do you know if the wheel/tire will stick out a lot or no? I want it to stick out but max 1-2 inches from stock.
Old 05-16-2007, 04:19 PM
wandell's Avatar
What's the backspacing? I'm not good with offset
Old 05-16-2007, 04:41 PM
wheel = 18x9, 6 on 135, Back Spacing = 4.52 in Offset = -12 mm
tire = LT325/65R18
Old 05-16-2007, 10:24 PM
wandell's Avatar
A 9 inch wide wheel with 4.5 inches of backspacing will stick out 2.5 inches farther than the OEM wheels. Personally, I would try to stick closer to the OEM backspacing of 5.5 inches.
Old 05-17-2007, 11:22 AM
so do you think this set up would be better??
I need to choose one of these wheels.
XD 795 Hoss=
20x9, 6 on 135 / Bolt Pattern; Back Spacing = 5.71 in.; Offset = 18mm
or
XD 778 Series=
20x9, 6 on 135 / 6 on 5.5 Bolt Pattern; Back Spacing = 5.70 in.; Offset = 18 mm
the tire since Im looking at 20s will be this
BFGoodrich All-Terrain T/A with LT325/60R20
Old 05-17-2007, 11:28 AM
chumFX4's Avatar
The first one. 6 on 135 bolt pattern is the only bolt pattern that will work.
Old 05-17-2007, 03:52 PM
wandell's Avatar
I think the 5.71 inch backspacing would be better personally.
Old 05-18-2007, 12:26 AM
If it was you wandell what kind of wheel would you put there?
I really want 20" and black if possible.
Im gonna definatly stay with this tire BFGoodrich All-Terrain T/A with LT325/60R20 just cuz they r quiet, great mileage out of them and good for my offroading.
Quick Reply: new tires and wheel but....
