Larger Tires = ABS troubles???
I was talking to a few people and they said if you go with too large of a tire (I was talking about going with 35's), that the ABS will not work on these trucks unless you buy sme ABS adaptor or something (around $50-75).
Does anyone know what I am talking about or had any issues going to 35's from stock tires?
ABS relies on the delta between wheel speeds. Since all 4 tires are the same size from the factory, keeping them all the same relative size is all that matters. Like Bryndon says, only if you put different size tires on the same vehicle at the same time would it matter. Your transmission shift points are the most affected as far as performance goes.
