tire weight
Old 05-31-2007 | 01:04 AM
Koosh's Avatar
tire weight
How much impact does tire weight have on fuel economy?? I'm just curious. I know that diameter and width effect fuel economy. But if you were to get a tire in a similar size, just heavier (d or e rated vs. standard) how much of a difference would that make?? any??
Thanks in advance!
Old 05-31-2007 | 09:45 AM
slash123's Avatar
Weight will make a pretty big difference being that the more a tire weighs the more power it will take to get it rolling, but there are so many other factors to consider such as rolling resistance, etc....Stick with a C rated or D rated tire. E rated tires are really unneccessary unless you tow alot of weight every day.
Old 05-31-2007 | 09:38 PM
Not only will a larger, heavier tire cause you to use more fuel. They also are harder on the brake's, shock's and whole drivetrain in general. My 35's use about 2 mpg more on the average compared to my 33's or my stock tires. The biggest decrease is in city driving.
Old 06-01-2007 | 07:59 AM
kingfish51's Avatar
Did you have the speedometer corrected for the larger tires? If not, that may be your difference in mpg.
Old 06-01-2007 | 01:33 PM
wandell's Avatar
Right. If your speedometer is off, your odometer is off also.
