Help with 2005 front brakes
Originally Posted by 05F150Tex
I'm about to change the front pad. Any special tools needed or will regular allen wrenches suffice? This is my first time changing the pads on this truck.
Originally Posted by goldmember
I have a set of wagner rotors and wagner thermo quiet pads sitting in my garage. I need to get this done. Only think I'm not sure if it's needed is any lube for the caliper bolts. I haven't pulled it apart to see how or why lube may be needed.
Shoot, thanks for giving me the fair warning. When I did the front brakes on my old Durango the rotor just came right off once you removed the caliper. I'll have to search for the right size and p ick up the socket.
Originally Posted by bluejay432000
No Allen wrenchs, just a metric wrench, I think it was an 11, and a C clamp to back the piston off. Do a search, there are several threads on the process. It's very easy and simple.
Thanks again for the quick reply.
