Is a custom Tuner my only option?
I went from stock 255/70/16 to 285/60/18. I know my spedometer and odometer are off but would like to get this corrected.
I have 3:55 LS gears ony my 2wd supercrew, do I need 4:10 gears?
Is a tuner the only way to correct the speedo and odo?
thanks in advance....
Yes, the dealer can correct your speedo and shift points, BUT I believe this is only if you stick on stock sized tires (or something that works out to the same diameter as a stock size tire) This is what my dealer told me, and I have heard it a few times on here.
Superlift makes a thing called the "TruSpeed" I think. You can adjust it for about any tire size there is.
Otherwise you will need a tune.
