what lugnut pattern?
Old 07-25-2007 | 05:15 PM
thebigkg's Avatar
i have a 1998 f150 extnded cab v6 and im turning it into a rat rod themed truck and im trying to find some steel old scool rims but i dont know what the lugnut pattern is thanks
Old 07-25-2007 | 06:32 PM
kingfish51's Avatar
5x135mm. Note, that is not the same as 5x5.5".
Old 07-25-2007 | 11:35 PM
wandell's Avatar
Right.
Old 07-26-2007 | 04:05 AM
thebigkg's Avatar
so would 5 x 4.5 or 5 x 4.75 fit?
Old 07-26-2007 | 08:16 AM
kingfish51's Avatar
No. 135mm is about 5.32". Just look for 5x135mm wheels.
Old 07-26-2007 | 09:30 AM
APT's Avatar
APT
And nothing smaller than 15".
Old 07-26-2007 | 09:53 AM
keith_bennett's Avatar
right
Old 07-26-2007 | 10:08 AM
kingfish51's Avatar
Actually, unless you grind the calipers, you can not use 15". 16" is the smallest.
Old 07-26-2007 | 12:48 PM
APT's Avatar
APT
Opps, that's what I meant. No 15" wheels, or smaller than 16". Thanks!
Old 07-26-2007 | 01:10 PM
wandell's Avatar
RIght. Your bolt pattern is 5x135mm. Nothing else will fit. You also have to use a 16 inch or larger wheel.
Old 08-12-2007 | 05:30 PM
Pro Skate Ramp's Avatar
Now I need help!
I was looking on here to confirm my lug pattern as well. I also have a 98 F150 3 door 4.2 and was told by Big O tire that I had a 5 on 5 pattern. (they told me without looking at it) I noticed that the guys on here said it was 5 x 135 mm and I kind of figured they were the same until now. Now I'm confused. Are they not the same?
Old 08-12-2007 | 06:41 PM
kingfish51's Avatar
They are not the same. Ford hasn't used a 5x5" for decades, if ever. They used to use a 5x5.5", then in 97 switched to 5x135mm (about 5x5.32"). Now they are using 6x135mm on the 04 up.
Not sure what the Rangers use, it may be 5x5", but I doubt it.
Old 08-12-2007 | 06:51 PM
Thanks for helping me on that.
I'm getting a deal on a set of 16" x 8" rims but they are only available with a 5" backspace. What is the difference between a backspace measurement and an offset? Also, how far out do you thing these will sit on that truck?
Old 08-12-2007 | 07:27 PM
kingfish51's Avatar
Check here for info.
Old 08-12-2007 | 09:57 PM
Thanks bud, you've helped me alot. I'm a pro when it comes to vehicle wiring, custom aftermarket electronics and troubleshooting, as well as body & paint.
This whole thing caught me off guard. Thanks again!
