Brakes dragging
before replacing caliper, take it off ,regrease the pins and flush and refill the system.my driver side would do that sometimes. i did all that and it hasnt happened since. that is probably the factory brake fluid. over time the fluid breaks own and can cause issues like this.especilly in the rubber lines. calipers usually last the life of the truck assuming the rest of tht system has been maintained.
You'll want to bleed the brakes after, but a full flush of the brake system isn't needed - the fluid can't cause dragging brakes.
When you go to clean the pins, check if they are really corroded. If that is the case you should be able to buy a new pin kit... cheaper than new calipers. At the same time make sure you have rubber boots that seal tight around where the pins slide out. You might need to replace those.
Once that is done, going through mud shouldn't cause an issue. As long as your rubber boots are intact this should be a long-term fix.
mkosu04
I have the same problem with the front discs dragging on my '98. Was told the brake hoses from the frame to the caliper needed replacing. I did this a couple of weeks ago, worked fine until Saturday. Brakes started dragging again. If I disassemble the caliper to regrease the pins, what grease did you use??
Thanks,
jack diamond
Thanks,
jack diamond
Originally Posted by jack.diamond
mkosu04
Thanks,
jack diamond
Thanks,
jack diamond
For greasing... you'll want to use a brake grease that specially formulated for the high temps, etc. I'm not sure the name of them... but here is one I found online...
http://www.autobarn.net/crcbrcasygr.html
I would think that AutoZone, NAPA, etc would all carry at least one brand.
And here is another site that talks about greasing the pins
http://www.aa1car.com/library/2005/ic80560.htm
Good luck!
I went ahead and put new brakes, rotors, and calipers on. The boot on one of the caliper pins was not sealed, so that may have caused the problem. I've only driven about 50 miles since, but so far so good. I did notice that when I bled the brakes that some of the fluid was very dark, I assume this was from it getting so hot.
I lubed the pins on the calipers with stuff they have on the counter at advanced auto. It was in a small pack and labled for calipers.
OK, I'm having the same problem.
Year: 1998
Model: F150 XLT 2WD
Engine: 4.6L (W)
Brake: Front Disc, Rear drum (Rear ABS only)
We had a VERY hot day the other day and my after market tire pressure monitoring system alarm went off (high temp alarm) the tire was over 200F!!!
Well, the tire pressure monitor replaces the air valve and mounts directly to the alloy rims. After some checking of the tires I finally realized that the rim was over 200F (not the tire) a quick check with my IR thermometer showed that right front brake rotor was almost 600F (the left front was around 200F).
I decided to give the truck a complete front brake job and replaced:
The over heating problem was not fixed (and I damaged my brand new pad). So, I replaced the pads (again) and installed a par of re-manufactured calipers (~$42/each before core deposit).
So, I've replaced:
And the problem is still not fixed (after a 10 minute drive the left brake disc is at ~150°F and the right is 250°F to 300°F!). I've been working on cars for over 35 years, and have done dozens of brake/wheel jobs, but I've never had this kind of problem.
Any idea?
Year: 1998
Model: F150 XLT 2WD
Engine: 4.6L (W)
- Rotors
- Bearings
- Pads
- Flushed the brake system
So, I've replaced:
- Rotors
- Bearings
- Pads (twice)
- Calipers
- Cleaned and greased the caliper pins
Any idea?
