Curb weight, tire load?
Does anyone know the curb weight of a 2004 screw lariat. It is 2wd, automatic with the 5.4l engine. This truck also has the short 5.5 foot bed.
I believe the new tires that were put on my truck are a little under rated. The tires that are on are Bfgoodrich Radial Long Trail T/A size P265/60R18 109T M+S. On the tire itself its says the max payload is 2271lbs and they are 2 ply construction. At 35 psi which is what the tire says, no matter how the truck is parked on flat surface or on an incline it always looks like all the tires are low.
Has anyone notice this?
Should I have choose a tire with a 3 ply construction?
Or am I being too critical?
My wife drives this truck so I want to make sure it is safe.
Thanks Kevin
Thanks Kevin
Unfortunately, you can not go by the weight on the tire when used on a light truck. The real weight carrying ability is lower. Your truck has a GVWR of about 7200lbs and an GAWR (axle carrying ability) of about 4000lbs. You are at the limit of those tires. Personally, I prefer a load range C LT tire. You can use what you have, but you can not overload the vehicle. Those will handle okay, but the vehicle will lean more in turns etc.
Looking at the BFG site, those tires are rated at 2065lbs at 35psi. so you lose about 200lbs carrying ability in this case.
One thing to make sure of is that the tires do not go low on pressure. Keep a good track of the cold pressure (35).
Thanks for the info kingfish51.
I knew I should have gone with a higher load, but we just got this truck. I had the dealer put new tires on and I told them just put on what was there before.
Luckily at this time I not towing anything at all, not even stuff in the rear. May be in a year or two I might so then I'll worry about getting new tires.
I have had these tires for about 3 weeks less than a month you think I could return them and get better.
Kevin
Kevin
Kevin
Screw Onwers Do not by BFgoodrich Radial Long Trail T/A's
Bringing back an old thread,
So we have been driving this truck for about 6 months now. The tires are looking scary the 2 front tires with 35 psi now have a larger bulge making them look like they are going flat. It is getting so bad that people will tell me i need to put air in them.
So after doing some more research I see that I should have gone with the BF Goodrich AT. I checked there stats and there Max load is a whopping 3300lbs that is 1300 more than the ones that are on there now. I just can't believe more people haven't had a problem with these tires on there truck, I see tons of Ford's with them and they look fine. Well live and learn I guess.
Please people anyone looking to buy new tires for there Screw DO NOT BUY BF Goodrich Radial Long Trail T/A's they just don't have enough load capacity for the truck. Add a couple of people and some stuff in the back and you got a disaster brewing.
As soon as I can get the money these may pop's are coming off.
Kevin
Kevin
