Rear Diff ABS Speed Sensor Problems (Broke)
I Just tried to remove the rear wheels Speed Sensor mounted on the Diff. I took the Connector and the Bolt holdling it in the Diff easily enough, but I had difficulty pulling out of the diff. After about 15 minutes of fiddling with it, it finaly came apart. I mean Apart like the coil pulled out in my hand and the rest is still in the Diff.
Any Suggestions as to what Next. I put it back together and I can still drive it but, of course the ABS light is on...
01 4X4 with 4wABS Supercrew
Thanks in Advance to anyone that will help out
Dpostman
Dpostman
Those are all dandy pic & all, but I must be slow or something cause I'm not finding the answer to what i'm looking for. I can see in the Diagram where the speed sensor is, but since "I" broke it, I already know where it is. On one pic, it look like it may be clear to get to the sensor from the inside but the pic was taken at an angle and it is hard for me to tell.
Is there a specific pic I should be looking at?
Dp
Dp
